Got a weird problem with my turn signals, anybody got any idea what might be wrong?
Hazard switch works fine and all 4 corners flash as normal.
Operate the left turn signal switch and it works as normal. Operate the right turn signal switch and the lights work as normal but the hazard switch light on the dash also comes on and flashes. It only comes on with the right turn, not the left.
Hazard switch is wired up exactly as Pantera Place diagram. Turn signal switch is stock as is the wiring.
Looking at the Pantera Place wiring schematic for the Hazards/Turn signal mine is wired the same so I have no idea on this one.
Cheers
Horace
