heck yes................I am going to the May event. the car runs, I have half of the fuel injection figured out. Was just pulling boots to read the spark plugs and pulled ignition wire off the # 1 cylinder and the clip that connects to the spark plus just pulled off the ignition wire.....balls!!!! I will fix it in the morning. From what I see from the plugs I am running a bit rich, they are a dark brown. Tomorrow's task..... fix that ignition wire and then twek the fuel curve a bit to take some fuel out................. C U at CSD pocono Doug.H
