If it moves out of neutral into a gear then try to identify which gear it goes into. Then set the shift shaft to the splined shaft on the trans and the shifter should want to go to the gear position inside of the car. Once you tighten the shift shaft see if you can find neutral and the other gears. If not then keep playing with it until you get it right. Good luck.
