So I ran into a new problem this weekend. Hope someone has some advice.
I went out for a joyride to enjoy the day when all of a sudden there was a big "CLUNK' when I dropped the clutch. I shifted into 2nd and got a similar "CLUNK". It sounded like a 4WD when you drop it into gear under load.
I immediately pulled over to the side of the road. It sounds like something binding or broken. It does it in 1st, 2nd and Reverse. Probably other gears too but I didn't try it.
Any ideas if its the Axles, Half Shafts or ZF ? I noticed even when the car is turned off and I roll it then you hear the "CLUNK". It seems to be coming only from the driver's side which makes me think/hope its not the ultra-expensive ZF that needs attention.
Any advice/help would be appreciated.
Tony
Tony,
The first and easiest thing to check/fix is to ensure that the bolts attaching the half-shafts to the hubs and to the ZF are tight. If not, then you need to isolate what is loose. It is possible that it is something hitting the car frame as well, such as a broken exhaust hanger letting the mufflers bang around. These are not super-likely causes, but they are ones that are easy and cheap to fix. Getting the wheels off the ground and moving things around may produce other symptoms.
Good luck. I hope others chime in, and that the answer is found quickly and inexpensively.
Mark
Hi Guys, the advice I got is that its probably bad universal joints (in the half shaft). It ran for a bit before I turned it off - I didn't want to damage anything unnecessarily.
It did sound like a u-joint. I'm going to try replacing just the u-joints not the entire half shaft. Does this seem like a reasonable plan or am I wasting my time ?
Tony
Not at all a waste of time.
If your shafts are stock, you'll need to hook up with a vendor to get replacement u-joints; they are no longer terribly expensive.
If you have Spicer replacement half shafts, those should be available locally. The permanently lubed units are fine for our use - P/N 5-801X. That means no annual grease gun adventures with the subsequent grease slinging all over the engine bay/bottom of fiberglass tub.
Probably best to press these in rather than the old hammer and socket routine. If you have a press, fine. If not, pay someone for an hour of their time and save yourself the headache.
Others may say to use the joints with the zerk fittings.
I too had always leaned towards those units, until this year.
I replaced all the joints on 2511. The guy at the driveline shop, upon hearing that the car only got 5-7 thousands miles annually, said go with the permanently lubed units. He said they will last at least ten years at that rate.
Once you remove the half shafts you will find that they are two piece shafts that slide apart. Be sure to keep them in pairs because they are balanced. Also look for a line scratched into the metal on each piece where they slide together. This is an alignment mark and they should be reassembled so that these lines are aligned for proper balance.
Mooso
Mooso
Mine (1971) were marked with a small triangle stamped on each end.
Mark
