Not sure what you mean. The additional metal is not visible from behind the car; just the inside. Although it's hard to see in the photo the part with the green etch primer is sealed with the new metal but the right side has not been done yet. It really closes it off around the bottom of the tail lights and the opening in the cross member. Probably stiffen it a little too.
I have a trans cooler going where the A/C was. I want to keep airflow for it but I wanted room in the trunk to use. If you remember I took the headers over the suspension instead of the 180's. The trans mounts L/R I added have 5/8 nuts welded under the plate. The plan is to build left/right storage bays which bolt in and can be removed but don't block the trans cooler.
That I don't have to work out now.
