i am having a puzzling backup camera issue    i hard wired a backup camera a few years ago    quit working no obvious cause    ordered a new one
so cant get it to work
i have 12 volts  going  to the switch and 12 volts to the outlet tab on the switch when car is in reverse but when i hook up the white wire that goes to the back up lights  i get no voltage on either side of the switch  if i use a power probe go the wire that would go to the back up lights (the white wire) the lights come on  i tried a second back up light switch w same result    no fuse blown or wires heating up
any ideas?
thanks in advance
joe
