AFAIK, they are the same. Does yours have a nut on the INSIDE of the cover?
If so, is it a VERY THIN nut?
Is the cover threaded?
If the cover is NOT threaded, and you have a VERY THIN nut on the inside of the cover and it still prevents reverse gear engagement, then you will have to try a different approach.
Options:
1. If there is NOT a second thin nut on the outside, try adding a second thin nut on the outside (or shims).
2. Helicoil the bore in the ZF cover. Use a thin nut on the OUTSIDE as a jam nut.
3. Find a switch with slightly larger diameter threads and tap the bore in the cover to match the thread size of the new switch. Use a jam nut on the OUTSIDE of the cover.
John
