We all know how expensive ball joints are for these cars. Well, I just stumbled into a possible interchange. I also own a 1972 Jensen Interceptor II that is currently under going restoration. When inspecting the frontend, I notice that the upper ball joint appears to be identical to those on my Pantera. I'll do a little more research and take some measurements, but if I'm correct the savings are unbelieveable. The Jensen uppers are available from mutiple sources for under $40.00 each.
Does anyone have any knowledge about this possiblility?
