Originally posted by lastpushbutton:
I'm guessing that is the fast and loud Pantera ....you can bet that everything is stuck, from the calipers to the rotating assembly. I betcha the shift linkage is stiff at the least.
This appears to be a different one. The center console is different, it has different valve covers and air cleaner, the carb is still on it (the Fast & Loud's had been off for a LONG time). The F&L one also had Good-Year Arrivas, square speakers in the door panels above the armrests, and it was missing the rear bulkhead cover and bulkhead panel cover.
