There is currently a BAT auction for a 72 as a “project”. I have seen this car and it is way beyond a typical restoration project.  Every panel has rust through, and that includes the sub frame. It has not been run in decades. The engine would require a complete overhaul. The ZF internals are likely beyond a rebuild. The auction is currently at $12.5 with 6 days to go. Unless you are skilled metal crafter and can do your own mechanical work, this car will likely cost double to “restore” than what is actually worth.
