I installed a Battery Tender Plus 3 years ago. Works perfectly. Car is always plugged into it and my battery is always topped up. Prior to that, I would kill a battery in two years from extended lack of use.
I hardwired the Battery Tender loom into the front trunk and dropped the lead out the front along side the radiator. When I want to connect, it is just tucked up inside the front valance.
I have other friends that also use these exclusively and have had no problems.
Highly recommend it for $50 bucks - you can not go wrong.
Otherwise, your battery will just sit and eventually puke.
Lee
I have two here one from my Harley that is now on the Pantera, the other is on my mother-in-laws RV in the pole barn. That camper sat from August to June and fired right up. Both batteries in that thing still were full of water when we fired it up. A very good friend of mine has BMW bikes...still has the same battery in one bike for 7 years. Battery Tender kept!
Jeff
