Thanks again for the brake booster info. My main problem is I can't get any peddle pressure after I installed a new Wilwood master cylinder and brakes. I have adjusted the push rod in the booster at least 4 times and I must have bleed the brake lines 10 times already(at least my wife gets some exercise pushing the brake peddle). The peddle does not pump up there just is no brake pressure. Does anyone have any advice on what it might be?
