Hi Everyone Matg you were on track, its not my flasher, I played around leaving the hazards on, then turning off and trying blinkers, the blinkers went straight away and stayed on, I checked under the dash, wiggled  connections to hazards , thought about removing to clean contacts etc, but just kept testing on/off between hazards/blinkers all worked fine, I know where to look if it occurs again.  new flasher not required YET !!
