I have always been concerned how the handle end inside the cabin has held the bowden cable. The right angle going through the 7mm hole in the alloy does a 90 degree bend and is held with a round solder stop. The "pinch point" is then the sharp bend through the handle. So to alleviate this I drilled a 6mm bolt and then tapered the hole to accept the solder on fitting. I thought of simply drilling a brass bolt and soldering the cable into it, however figured the free pivoting end with movement would be better. Now the pull is straight and concise. Thanks Mike
