Team please help
running nice Willwood 4 pistons in the rear. Unfortunately one of the fittings got a bit loose resulting in rubbing the braided brake line at the half shaft.
The line is app 1.5 foot long and has the L shape fitting at one end going into the center of the Willwood, the other side is straight .
Line is still ok but 2 or so steel threads stick out. Def a safety issue.
Looks like I can have the line custom made, but before I take it out for the shop as sample DOES ANYONE KNOW the tech spec?
1) length
2) Fitting measures, the nut is 1/2 in, thread??
Please Help!
Matthias
Hi Mat -
Im not near my car now, but I thought the Wilwood ends were standard 3AN…
You can possibly look it up to confirm on their website or call Scott at SACC.
I converted my bulkhead fittings to 3AN so I could use a standard fitting.
I hope this helps… If not, someone smarter than me should jump in and correct me…. Like my wife!
D66A1E75-9672-4EC3-A528-D374271F572C
  • D66A1E75-9672-4EC3-A528-D374271F572C
