My brake booster is so close to my hood that it actually touches the hood and pokes a slightly visible bend in the hood when the hood is closed. I tried different caps but even with the smallest cap shaved down, the cap still touches. Is there any way to angle the booster down somewhat, maybe by a couple small washers at the top portion where the booster panel connects to the body of the car, or would this possibly cause mechanical problems. From the link below, you can see how close it is to the hood. I was even thinking of filing down the screw portion of the resivour somewhat, so that when I screw the cap on, it then "may" go lower. Anyone else ever have problems like this when they upgraded their brake parts?
http://community.webshots.com/photo/97287519/142868319kgpoTS
