Can I get confirmation that the stock booster is 7" and a single diaphragm?
Somebody had a better idea and jammed a 8" booster in mine. I had to pry it out and broke the push rod, okay fine it doesn't belong in there anyway. Now I'm wondering if they did that to overcome the low manifold vacuum of about 8 inches. Would this in fact make a difference, and can I go back to stock and be okay? I've seen some 7" units and they say you need to have 18-20" or you'll have to use a vacuum pump. Doesn't sound right to me.
I don't know the original booster diameter.
to help me visulize your question, I tried to make a graph that shows the amount of extra force that a 7 or 8 inch booster would provide at different manifold vacuums.
at 8" of vacuum, the differance between the 7 and 8" would be about 10 pounds force at the pedal. neither one of them provides much assistance (about 40 pounds).
so going from the 8 to 7" booster, to get the same braking with 8 inHG manifold vacuum, you would have to push 10 pounds harder on the pedal. IF the manifold vacuum were to increase from 8 to 11 inHG, you would not notice the differance between the 8" to 7" booster
force at the pedal assumes 4.3:1 brake pedal ratio
  • brake_booster_force
