If that booster system is from the Byars Bros, it is a modified GM booster (unidentified model) and master cylinder. GMs all used a 3-stud attachment to the firewall and Byars changed that to 4-stud to bolt into a Pantera, then gold-alodined the assembly. The booster can is slightly larger than a stock Bendix-Italia booster for a Pantera.
The aluminum MC is a dual-bore GM type with the front circuit having a larger piston than the rear. There is a stock built-in 2-psi keep-alive valve in the front outlet to improve pedal response. Don Byars could give you more specifics.
