Front and rear stock brake calipers off of a 1973 L with 25,000 miles. Working perfectly when removed and replaced with Willwoods. Lots of pad left and all are fitted with speed bleeders. $200 + shipping
Where did you get you Wilwood Calipers and Rotors??? I've been looking at doing the same project and haven't come up with parts from Wilwood that fit and are all Wilwood...do you have part numbers? Which calipers are you running front and rear? How do you like the brakes?
I got them off of a wreck that I bought. I believe that it was a set bought from Hall Pantera. I lucked out they had the small calipers that fit the 16" wheels that I have on the front. I hear that the newer ones have larger calipers that fit 17" wheels and larger. The brakes are a large difference from stock. I'm sorry, I don't have the part numbers.
