We now have our brake kit available on our website.
We also have a new Brake Kit.
This brake kit is for 15" Wheels.
This is a very unique kit designed for performance at an affordable price.
Includes BIG 12 inch Drilled, Slotted and Vented rotors, front and back. Great looking hats mounted as the factory intended (won't affect wheel offset positioning). Billet 4 Piston Calipers up front and 4 Piston Calipers in the rear.
Includes all hardware for installation including Caliper Brackets (front and rear), Hat bolts, Caliper mounting bolts and instructions.
This kit is only $1995.
http://pantera.saccrestoration...akes-brake-kits.html
Hi, trying to find a pic of this kit. Does it have the facility of e/ brake ? via the std caliper ?
Hi,
To keep costs down this kit does not include an e-brake. We use the stock rear caliper for the ebrake which works quite well when adjusted properly. Instructions are provided to implement the use of the stock caliper for the ebrake.
Are you interested in the 12 inch kit or the 13 inch kit?
Take care, Scott
