Used to have brake lights, now I don't. Have all other rear lights. Brake light swtich is 25 years old, any way to test it ? Anybody know where to get another one ? Thanks.
To check if it's a bad switch, just bypass it. Connect the two wires that go into the switch. If your brake lights illuminate, then viola, you have a bad switch.
