...I understand that these Restrictor Plates; that press into the pocket, in the 351 Cleveland Block, just under the Themostat; are near impossible to find!! My Solution: I just finished Reverse Engineering, Drafting, and Machining a Matching 'Punch and Die' Set, to produce these in numbers large enough to meet everybodys needs. I have the Brass Sheet and we are turning them out as You read this. The Material is Pure '260' Yellow 'Cartridge Brass'. Highly Resistant to Corrosion. Beautiful!, You'll hate to hide it down inside the Engine Block. The Same Dimensions and Thickness of Brass. ALL the Proper, and Correct Fillets and Funnel Shapes are there. I create Them Better than the original! Different only because the word 'TOP' is NOT Stamped into the metal. If You know what these are, and How they are Installed; You already Know which Side goes UP!. I am selling them for $35.00 Each. Plus $4.55 for Shipping to the US ONLY. Sure Beats that arodited steel piece of junk, some poor soul paid $79.00 for on Ebay, last week! Contact Me at: pantera1974@verizon.net Thank-You!...
