While cleaning up the 5-0 Pantera's engine bay, I discovered that the rear mount had partially broken off the from the rear of the ZF-1 case. At first look, it appears that the studs broke. I'll know more when I disassemble tomorrow. I know that this mount is a weak point. Is this how it normally breaks?
Images (4)
  • mount1
  • mount2
  • mount3
  • mount4
Dennis, LOOK OUT! The same thing happened to 1362. I tried to drill the stud for removal, when the drill turned it screwed the broken stud into the ZF. The hole has no bottom! You can use a left hand drill and turn it counterclokwise. I bet it comes out easy that way. I had to remove mine and shake it upside down to get the broken stud out. I went back with side mounts fabricated by PI. I think they were just over $100. They attach to the studs behind the sway bar caps. The side mounts are much better IMHO. I can send you some pics at your request. Bill
