I've been researching this topic here and other places, but I haven't come up with a definitive answer, so I'll ask outright.
Do I absolutely have to remove the outer steel sleeve from the control arms to install new poly-graphite bushings? From what I can tell, the poly graphites don't have an outer sleeve of their own. It seems to me that the bushing would function better with the old sleeves in place (radiused edges, smoother finish, etc.) rather than removing them and having the bushing ride against the raw control arm. Its a well documented PITA to remove the sleeves, so before I go down this path, I want to find out if anyone has tried it without removing the sleeves. Thanks for the help.
John
