Can someone with a Deauville/Longchamp check the length of their C6 transmission dipstick for me? There is a Ford part# on there as well, that would help as well.
Mine didn't have one and the replacement I got from a breaker isn't correct I believe. The number on it suggest late 80's Ford so likely for an AOD I guess.
I think it is too long, 56 cm from the bottom of the rubber seal to the very tip.
which would mean a low fluid level and at least a partial explanation for the poor pick and hesitation when going from D to R and vice-versa.
Thanks in advance.
Chiel
