Here is the question.. there are vents to get air into to cabin.. theoretically.. warm or outside air or A/C cold..
but usually cars have a venting system that, for example you close the door let the “trapped” air escape… surely you saw vents in the rear of the doors towards the door-jam or behind the sides in the rear of the body, hidden behind the bumper…
so, where is that feature on the Pantera cabin?
I’m just wondering if you want to add cold air to the inside the air present in the cabin has to go somewhere… if not, there won’t be much cold air coming in!
just a few incidental air leaks won’t do the trick…
