This is driving me crazy. I have a new slave, master, and red tube. All stock. I have used the Mighty Vac tool, connecting it to the top of the slave, also have tried a Speed Bleeder, and lots of pedal pumping. At some point I get the air out and a firm pedal, but not quite enough to get all the gears. When I try and get more out, I loose all the pressure I have built up, and it appears I get air again, and a very light pedal. It does this over and over.
Basic hydraulic question. Is it safe to assume that if I had an air leak I would have to have a corresponding fluid leak? I can't find one any place.
If the NEW master was bad I would think I could still build and hold pressure, same with the slave. Again, no leaking.
Can't figure out how something so simple can be so confounding! Thanks.
