Originally posted by 4NFORD:
So, your groaning noise was coming from the cylinder and oil additive stopped it? Any idea what it was that they added? I still have some noise, I have to check, maybe its coming from my cylinder too.
Hi Dennis. It was a simple fix, just call the place where you got your direct lift and they can get you the lubricating fluid to add. All I know is they referred to it as catipillar juice. Lift works perfect now. It just lubricates the seals of the cylinder.
By the way, I am getting better at backing the wide bodies in the 4 post lift. I now hold a small 4" mirror out to the side while backing in, so that I can see my rear tire on the lift, I also have a baby monitor wireless video on the rear, which helps too.
