I might be a little late but I have a brand called Stinger. Have had it for 10 years. I believe it is the best piece of equipment I have ever bought. It went together and works great. I never bolted it down because in my last garage turned it side ways using the casters to store the lift side ways once the car was on the lift. I have even rolled it outside my garage to use a pressure washer to clean the underside of my truck. I had to tweak the relief valve a little, but now it will lift my 3/4 ton diesel short box crew cab.
Originally posted by 4NFORD:
My wife and I discovered that it is easier for her to guide me from up front. I can see her better and she doesn't have to eat carbon dioxide. The Mangusta is a bear to back on the ramp, you can't see anything!
I have 2 convex mirrors mounted on the left side posts (one at the rear-allowing me to align with the ramps and one at the front-to make sure I'm straight).
I also used "chrome" spray paint and masked off a "high vis" alignment line and "stop" line/mark. Finally, I hooked a spotlight up to my garage door opener so that when the door moves, the front left quadrant (with the mirror, tire/wheel, and ramp (with alignment stripes) is illuminated. :-)
On garage lifts, you have several styles- there are two-post side lifts, 4 post lifts and the one poor boys like myself buy- a single post hydraulic type from a bankrupt gas station. Going price is $500 and you move & install it. It runs off a 1-horse air compressor and has three heights of safety locks. It installs easily once you dig a 7' hole 24" in dia. The column slides in and is backfilled with dry sand. In some areas like CA, the cylinder with 45 gallons of hydraulic oil is considered to be a 'hazardous waste container' and they want you to build a concrete containment pit with an alarm & sump pump in the hole. Mine's in NV, and we don't mind other people's business.
With a single column, the center of the car is inaccessible and with the 4-post types, the suspension is inaccessible. Unfortunately, I couldn't afford the two-post side lift type which has no inaccessible areas, but a friend in the Bay Area had trouble with his new (Bend-Pak?) 2-post. For the 1st try, he lifted his wife's 05 Caddy to 7ft. At full lift, one cable popped off the ram, dropping that side 18" until the safety lock engaged. This left the expensive 4000-lb car slanted sideways at 30 degrees, 7 ft in the air. LOTS of quick work by 3 guys with floor jacks and 4x4s to push it back up to where the loose cable could be put back onto the hydraulic ram top. Turns out that one hydraulic cylinder was slightly bent in shipment; he quickly made a pair of steel plate brackets and tack-welded them to the tops of both rams as cable guides. Always something.....
Tomcat, I would love to see photos of your mirror set up. I would think the convex mirrors would distort too much to really see where you are on the ramp. I got a "baby monitor" small wireless camera with a 3" monitor that I am going to try to see how that works. With my wide body, I don't have much room on the sides, and if I start getting slightly crooked on the ramp it just aint good. Your mirrors sound like they may work, let me see what it looks like, thanks.
I think that mirrors that are large enough to see the length of the ramp on both rear pillars are the key. My 335/35's take up a lot of the ramp and sometimes in getting them centered my fronts become crooked. I guess being able to see the length of the ramp and maybe border lines will make it a one shot deal. I must be getting old, its getting harder every year!
The baby monitor worked pretty good for backing the car straight on the ramps.
Tomcat, I would love to see photos of your mirror set up. I would think the convex mirrors would distort too much to really see where you are on the ramp. thanks.
Mirror shown on left rear post. I lined the car up perfectly (the first time I had the mirrors) and sat in the driver's seat and got a good "sight picture" (1"-2" of exposed ramp beyond the width of the tire) and its been EASY ever since.
  • Rear_stacked_convex_mirror
Tomcat, thanks for the photo post showing the mirror. But I see you pull your car in forward. Have you tried using them to back in? That is where I had issues, backing in with a wide body.
I haven't tried backing...I think you have an issue! I might back it slowly with the driver's door partially open looking at alignment???
Do you jave to back it for ramp clearence or door/ceiling clearence?
Yes, I have to back in because of garage clearance over the front hood is lower vs the tall rear of the car (see my photo in the post above). I was just wondering if your mirrors helped backing in, but it looks like you pull in forward. The baby monitor video camera that I got works pretty good in keeping the car straight. I velcro the 2" camera under the car by the rear wheel when I am ready to park and I have the ramp marked with a strip of masking tape where the rear tire is to travel. Then I get in the car, watch the video while backing it in and make sure my rear tire is just on the tape all the way to the rear of the ramp. Another method that kind of works is holding a small mirror out at arms length out the window so you can watch the rear tire on the ramp as you back on the ramp. The side mirrors don't work well since you can't see the tire/ramp area. For those that don't know, it is real easy to get crooked on the ramp when backing in almost blind in our cars that you can't see well anyway out the rear. Start off just 1" at a crooked angle and you got big problems 1/2 way down the ramp before you even know it. Can't keep the door open either to look back, since the lift post is there. I usually do a good dose of valium before backing in, seems to help some.
Gee that sounds like a lot of work to back your car onto a ramp. I don't have a ramp, but I do hate to scratch my wheels backing into a parking spot. I also want to have a good view of all the blind spots around the car.
These $5 stick-on mirrors work fantastic. Yes, "Objects are closer than they appear" in half the mirror, but placed as you see them I have perfect vision all around.
And I can see my rear tires perfectly.
  • Slide1
With another car on the way I need a car lift as 6 cars into a 3 car garage just doesn't go. I decided on the Direct Lift, but I'll pay the extra and go for the Pro park 9 model to get the wider track ramps for the GT5.
I was in Larry Stock's the other day and happened to mention I was going to get a lift and he said he has 3 other people wanting lifts so we are going to see if we can get a discounted group buy. No harm in trying, if anyone here was on teh fence about getting one maybe an opportunity to join in. We are planning on having them combined shipped to Larry's shop in Reno, so you would likely have to arrange local pick up or onward shipping from there.
Brad,
Not sure what we can negotiate yet, but obviously the more interest we can get the better chance we stand. I'll see if I get some idea of what would be on offer for say a group of 6, 10 etc. (we have a definite 4 here already) and report back. I would hope we could get 10% or 'add ons' (I want the jack anyway) thrown in free.
Direct lift has a dealer in California. I think it was called Quality Tools. This is where mine was shipped from. The packed lift is about 14'x2'x2' and weighs about 1400lbs. It cost me $700 to ship to Hawaii. If you need it delivered to your home, the cheapest option is to hire a flatbed tow truck, they can slide it off to your driveway. If a shipper delivers it, you'll pay for the flatbed plus the fork lift. Once unpacked, you can carry it into your garage piece by piece. One man can lift the pieces by himself but assembly requires 2. A friend and I put it together in about 4.5 hours with no experience. We could probably do it in half the time now that we've done it before.
Superlifts came in at $2400 with 3 drip trays, castors and jack tray inclusive of freight to Reno. What I like about their 7,000lb model is its extra width for the GT5 (equivalent to everyone elses 9,000 lb model)
Direct Lifts came back with a quote of $1600 FOB Quality Tool Temecula, CA for the Pro-Park 7LL model. We are working on combined freight to Reno and it will certainly be less than if you did this alone. Alternatively I'm betting you could take advantage of the $1600 price and arrange your own freight to the location of your choice.
Hi guys.
Just wondering if anyone has heard of this company in Canada that is selling lifts:
http://www.carlift.ca/carlift_fortress.php#specifications
They have some good deals in market (including a price matching guarantee of being 10% lower cost) and are expecially attractive to me since their warehouse is located in Calgary (where I live).
I checked out their King and Fortress lifts in person today and then came home to compare their lifts to the Direct Lift Pro Park 8 (http://www.adgforward.com/directlift/pro-park-8.htm) and the Kwiklift Revolution (http://www.kwiklift.com/FourPostLift/index.htm). Their spec is very comparible in all areas.
I guess the only thing that is bugging me is I don't know who the manufacturer is ... at least not yet. I am going to make a trip back with an engineer who works for me to ensure I am not getting hosed.
Any feedback is appreciated.
ps. Thanks to Dave Londry and Mark Charlton for their feedback.
DL&DT,
Send me a PM with your contact details and we'll try and figure it out. We are picking up in Temecula CA and trucking to Reno, so we would have to figure out onward shipping to NYC. Using my company's account and 70% discount I got a rate of $1,200, so you may actually be better at least checking delivered prices with one of the suppliers closer to home. www.gregsmithequipment.com are advertising the Pro-Park 8 for $1695 (Call for better price) and they have a warehouse in Delaware to ship from. We are only getting a $100 discount on the lifts, the saving is in supplier proximity and combined truck freight.
Originally posted by Joules5:
DL&DT,
using my company's account and 70% discount I got a rate of $1,200, so you may actually be better at least checking delivered prices with one of the suppliers closer to home. www.gregsmithequipment.com are advertising the Pro-Park 8 for $1695 (Call for better price) and they have a warehouse in Delaware to ship from..
I used Greg Smith (I think I still have a testimonial on their site somewhere)and couldn't have been happier.
Additionally, $1,200 seems 4 times higher than I recall...but I DID have to have a loading dock and forklift to get my lift off the semi.
Very likely, my $1,200 quote was based on shipping one of our group purchase lifts from Reno on to NYC. Your comment reinforces the point I was trying to make as it is likely a lot cheaper for DL&DT to order direct from a more local source. Greg Smith has warehouses in Indiana, Georgia and Delaware.
Originally posted by DeLoreans and DeTomasos:
Point well taken, I will do some research here on my end. Thank you for looking out for me nonetheless.
The type of truck/transportation is HUGELY important.
Using an LTL (less than truckload) carrier...meaning using a "commercial" 40' or larger truck that just pulls up to a loading dock...where you/someone drives a forklift onto the truck and gets your product is 5-10 times cheaper than FedEx/UPS delivering something this industrial to your home.
When I bought my lift, I just had it shipped to the local freight terminal. I used Yellow freight because we had a corporate discount but so do most of the lift manufacturers. The Yellow terminal gave me a call when it arrived and I had one of the local tow service Co's with a roll-back truck pick it up and deposit it on my driveway. He use his winch, tipped the bed, and let it slide down the bed, and then with the bed still inclined, just inched away until it slid gently down the ramp onto the ground. For me, it was $350 for the freight (about 500 miles) and $69 for the roll back service. Of course, freight will vary base on distance.
High lifting the door was another story.
Kelly
I'm looking at installing one of the screw drive garage door openers that sits on the wall above the door, supossedly only needs 4" clearance. Then I need to figure out how to raise it by adding some track in the runner to get it to open closer to the ceiling!
Just be advised, there are some limitations to high lifting a door with a conventional spring balanced opener. Depends upon how high the door is lifted before it starts to feed horizontally, the weight of the door, and the power rating of the opener.
Conventional openers count on the effective weight of the door being lessened by the spring winding up and reducing the effective weight of the door as is closes. The higher you lift before the door goes horizontal, the more the spring unwinds and the heavier the door gets.
-Kelly
Great ideas...and the $s seem right to my memory
Kelly
