I have finally removed my ZF for a clutch change this weekend. I went thru the bulletin board looking for Clutch choices and Im still confused.
Centerforce sells a special order pantera clutch DF021048-s. Will it bolt to the stock Pantera flywheel? If not, can I redrill mine or do I need the CF flywheel as well. Should I use a long throw slave with the CF clutch?
I saw a post about using a spherical throwout bearing with the CF for linear clutch engagement, but can not find that part anywhere. Does the ZF use a standard Ford 351 throwout?
PLaces like PPC and Pantera east sell a centerforce that requires a new Flywheel and its a 10.5 inch clutch using a flat faced throwout bearing. Not the DF021048-s 11 inch version, that confuses me more.
Loyd and others mention the McLeod 360-505. Does this unit bolt to a stock Pantera flywheel? I have a stock 3 finger pressure plate and the clutch effort is fine. In my neck of the woods traffic jams last for minutes not hours!
I appreciate the help.
[This message has been edited by Choproxy (edited 05-20-2002).]
