Originally posted by Dave2811:
I just wanted to alert the forum with the information that the Centerforce DF021048S, or DF021048-S as it is sometimes is listed here is a discontinued part number. I just confirmed this with the tech rep from Jegs who called Centerforce while I was on the phone.
The replacement is the 10.4" DF021057S which will require re-drilling for the new clutch cover. Not such a big deal really considering the resurfacing guy should be able to do the drilling as well.
I spent many hours searching the forum and internet for the latest info on this, so I thought I would seed the database with this info. Thanks for the great forum so far!
Centerforce has superseded part numbers DF021048S or DF021048-S with part number DF021057S The Pantera clutch offered by Centerforce uses a different bolt diameter and bolt pattern than the stock Pantera clutch for mounting the pressure plate to the flywheel, therefore Centerforce includes qty. (6) upgraded 3/8 bolts with their clutch assembly. Centerforce offers a steel flywheel part number 700250-48 or a aluminum flywheel part number 900250-48 for a direct bolt in replacement. If you choose to re-drill your stock flywheel, make sure that you use the supplied bolts included with your new Centerforce clutch. Feel free to contact Centerforce with any questions.
