David, now that you have the broken mount bolt replaced, let's think about WHY it broke. The usual reason is, the rubber isolator discs tend to collapse more on the inside than the outside, from the weight of the engine, age and heat from the headers. That puts a bending-strain on the bolts and after awhile, one or more will break. The time-honored way to temporarily fix this is to rotate the rubber isolators 180 degrees while ordering new discs. Occasionally, old collapsed isolator discs will loosen a bolt enough to have it fall out. Sure, gr-8 bolts or tapping the block to the next larger size also stops the breakage temporarily, but the real fix is new rubber.
