As some of you know, 4507 has been getting alot of attention! Trying to get her on the road after 20 years of indoor storage. Got the motor running GREAT via a new fuel system from the tank to the carb.
Now, Ive noticed that my alternator isnt charging the battery. I tested it while the engine was running, not putting power to the battery. I pulled it off, took it to a local electronics specialist. Put out fine on his bench. Got a new ground strap to install, since it appears to be in bad shape. Can anyone point me to any other areas to check? Perhaps the voltage regulator?
Thanks!
