It turns out 9138's fluid looks like it has never been changed snce new. It has 40Km on it. The fluid looks a little metalic. A friend is going to analysis the fluid this week to see if its aluminum, steel or bearing material. Looks like it will be coming out soon and going for a rebuild sooner then I thought.
Ron
Originally posted by accobra:
... and what do we sue for gear oil ..reg 90W. any additive ??
Ron
Lloyd Butfoy has said that positraction lubricants won't hurt and may help some ZFs. He recommends 80W90 gear oil to be changed at the same interval as your motor oil.
Roy Butfoy recommended 80-90 weight GL-4 gear oil to be changed out every 12,000 miles.
Jack DeRyke recommends 80W90 posi-lube.
Many people swear by synthetic, even though it tends to cause leaks. Lloyd has said he likes Mobil 1.
See:
http://pantera.infopop.cc/eve/forums/a/tpc/f/6450045562...660037562#2660037562
http://pantera.infopop.cc/eve/forums/a/tpc/f/6450045562...980098562#2980098562
http://pantera.infopop.cc/eve/forums/a/tpc/f/6450045562...240009562#5240009562
http://pantera.infopop.cc/eve/forums/a/tpc/f/9550045562...960019562#2960019562
I am going to change mine since the owner could not verify how long it has been since the last change. I am planning on running Red Line Heavyshock, I thought I had seen it mentioned in a post and wonder who has tried it in there ZF??? I put it in my motorcycles transmission and I am really impressed at how much easier it is to downshift and it has made the tranny quieter.
Jeff
I found a 17mm hex head 1/2" socket in a kit with two others (13 and 15 I think) at Auto Zone for $10.
I had to cut 1/2" off the length to get it to work and used a 17mm open ended box wrench to turn the socket (since I still didn't have room for the ratchet).
I found some shavings on my magnetic drain plug but not too many (considering the last time the fluid was changed)!
I only got about 5 pints of fluid out...so I guess I was low.
7.5 is the volume RIGHT?
I only have 4 pints of Castrol so I need to find more...Wal-Mart, Advanced Auto and Auto Zone had none :-(
Thanks to this forum for helping me through the process!!!
