I've been experiencing overheating. I have a new aluminum radiator with a thermal switch that grounds the fan relays to activate the fans after the water heats up.
After overheating yesterday, I opened the hood with the car running and the fans were not running. I shorted across the thermal switch to ground the relays and still...no fans.
I measured the voltage on the pink wires on the fan relays (12V input) and got less than 1 volt. After the car sat for 20 minutes, the fans came on as expectecd. The pink wires were now reading 12V.
It appears there is a circuit breaker between the key and the fan relays. Where would I look for this thing? I have a manual but it doesn't have a wiring diagram. Where can I obtain a full wiring diagram for a pre-L '72?
If anyone is familiar with this circuit breaker, is is "special" or do you think I can obtain a replacement at a good parts store?
Thanks, Mooso.
