I believe the clutch has broken, put car in any gear, just like it is in neutral. clutch pedal feels fine, and shifter feels fine. car now has a webber clutch and pressure plate?. or so the records show. never heard of webber clutches. What do you guys recommend for clutches? just a driver, not raceing. Found a 1" spring on the ground. I think it comes of the clutch disc, around the center. will know more when I pull trans. Thanks.
