Am trying to reconnect the Effort reduction kit,
I have the arm the right way around but I still cannot by hand depress the clutch pedal (NO oil in the system just checking the Mechanics of the system)
I saw the video Rocky mentions on Provamo and took a still of it.
The position of the 3hole bracket is totally different to my own.
My angles are so wrong I have to physically lift the arm up 3mm at least before the pedal can be operated
please look at the pics It would appear that my Master cyl pushrod is too long?? anyone know how long it should be?
first pic is the provamo one second one mine.
best Peter
I am hesitant about adding my thoughts as it seems I get things more confussing, BUT, it is not in my nature to not jump in Big Grin
as for the master cylinder rod, there was a TSB article that implies the original had to be replaced with a shorter one (and remove spring to prevent it going coil solid)
my "opinion" is that the MC rod adjustment is to get you close, but the adjustment has to be to set the initial angle. If too shallow, the link LOCKS, Too great, and the full stroke is reduced
  • TSB10a89
Peter,
Your "dogbone" is installed correctly, so you can rule that out as a possible cause of your clutch difficulties. You're on the right track. It looks to me like your clutch M/C pushrod is too long, causing the linkage to bind when you depress the pedal. This is how it should align, if your pushrod is the correct length.
  • linkage
I can't help myself, even though no one proably cares, I'll post the graph of the linkage kinamatics I did back when I was still able to do such.
IF the clutch rod is adjusted so that "b & c" are in line (the white line), this is the 0,0 of the graph an implies that even though the amount of mechanical travel advantage is its greatest, the force required to push the pedal is tremendous (ie if is LOCKED).
the clutch rod needs to be adjusted so the starting angle is as indicated by the white arrow. HOWEVER, if the angle is to great, the mechanical advantage is nill. this is the graph for when pedal travle is greater than 1
  • clutch_pedal_effort_reduction_linkage_r1
Thanks David, thats something, also I had the rod adjusted at 79mm which I thought was its shortest length!
After removing the cylinder I found some more adjustment to go to 73.9mm
will fit tomorrow, and cut the rods extra unwanted threads,
JFB thanks for the rod length post again, your reasoning is logical, but I am a simple soul and still find "pressure beyond" difficult to understand in Hydraulics!
best Pete.
I got that photo online from "JB1490".
During Peter's last clutch discussion, the fact the dogbone was not symetrical was brought to my attention.
the sad thing I discovered at that time was I could not remember how I did the calcs to see how much differene it makes. Frowner
If "c" is made longer (by reversing dogbone, that might prevent the ability to adjust for the "b & c" to go straight line and lockup
Here is the News.
I fixed the length of the MC rod at 73.9mm
My Sachs clutch is light as a feather, and gears engage well.
I have 1mm play between the fingers and the throw out bearing, when the clutch is engaged.
AND its as light as a feather to operate.
so thanks to all you forum people who have put up with my Clutch woes for far too long, your assistance HAS been extremely valuable.
Thanks also to Roland Jaekel in Hamburg for his quality products that worked so well for me.
If anyone would like a trip over to Manchester England sometime the beers are on me!!!
Originally posted by David_Nunn:
....but it works better in the correct orientation.
(First PLEASE David, don't take my comment serious, but as the jocularity intended)
One of my pet peeves with the "techincal" reports of others is the phrase "made it better"...My peer review reply is "... you need to quantify the degree of better"
Peter, on my wish list will be that beer (and I don't drink)
I can do saspirella.
again my clutch isn't a bit better its working properly! Geronimo I believe is said in such circumstances.
Peter, I bought this for 90 US from Pantera Performance in Colorado. Before installing the pins just lube them up with a smear of grease.
JFB, I know what you mean, I was a little skeptical about this too. But they say it was good as the original bellcrank.
This is my third bellcrank, the other had elongated holes and the machine shop made a bushing for it, but only lasted a few years.
I'm trying this one out.
