Presuming that the clutch components are new, and you had the flywheel resurfaced,
1) needs to be Pantera specific
2) Specific Centerforce for Pantera will slip noticeably until it seats. That CAN be 500 miles but not always.
3) just fixed one of these where the pressure plate was not installed correctly over the flywheel dowels and as a result was being held away from the disc and not clamping it.
4) the cast iron hub on the disc is soft and CAN crack easy on installation of the transmission if you don't turn the transmission as you insert the input shaft through the disc hub. I know because I have broken them. An expensive mistake for me.
A broken hub can give you similar symptoms.
Depending on which clutch you have, Mcleod needs at least .035" clearance at release, the Centerforce needs .045".
Take your feeler gauge and measure through the observation port.
Verify that the clutch is physically fully seated at no travel, then what have you got at full travel.
Chatter could simply mean the disc is not being fully clamped into place?
Back off on the slave adjustment until you have the clearances above.
If it still slips, it isn't installed right.
Here's hoping it's something simple.
