I am ready to install my new clutch master and slave. Can you give me step by step instructions...ie.. do I have to remove the ckevis pin frum under the footbox?....or can I get to it when I unbolt the master from the firewall. I plan to measure my stroke and not to concerned about slave..been there and done that.
We just jumped right in there. One strange thing...I had to use my old rod that pushed the master in because it was 1.5 inches longer than the replacment from Hall. We also replaced the slave and it bled fine with a little tapping of the line... Thanks George in Hawaii...Still it ain't no ladies clutch pedal.
