need advice on which clutch master is best suited for my gt5.The original master is the benitalia one had that rebuilt but found the car was creeping whilst the clutch was down.Bought another one from ebay with the detomaso cast in on side of cylinder it was meant to be new however after instaling it i cant get pressure in the system.So now i am stuck need advice on which vendor will help me out?help emmanuel, sydney australia
Emmanuel,
Don't give up on your new master just yet. If you have pushed the clutch pedal all the way to the floor while attempting to bleed the system, there is a good chance the piston is stuck at the end of the bore. If this is the case, you will have to disassemble the master cylinder to free it. An air line might help.
When bleeding the clutch or brakes, only ever pump the pedal half way down (even on a new master cylinder). On an old master cylinder, there could be rust beyond the area that the piston normally travels. This rust can damage the seals and prevent the piston from returning.
Johnny
