getting close to getting her on the road, today while working on it I depressed the clutch but now it doesn't come back up, has only about 1" of total stroke, spring is good, clutch fluid looks good, any ideas?
quote:Originally posted by dad210:
...master cylinder, slave cylinder and braided SS line...
quote:Originally posted by JFB #05177:quote:Originally posted by dad210:
did you get all from a pantera vendor or the fiat/alfa site?
quote:Originally posted by Bosswrench:
Dad, there is a return spring inside the clutch slave cylinder. Not changing the clutch fluid for decades allows enough water to collect to RUST the spring in two! If this happens, the slave piston may not return properly. Second thing that may have happened is, for whatever reason, you used more clutch pedal than what the system was 'used to'. Varnish builds up at the ends of travel in cylinders and the slave piston may have over-traveled into a place where it bound up.
Disassembling the simple assembly and cleaning the cylinder & piston with scotch-brite may restore its function. Do NOT power-hone: there's only one seal in the ass'y and if the cylinder is only slightly enlarged or bell-mouthed, you may build a leak where there was none before.
The reason I'm suggesting these is, brand new reproduction clutch slaves have a recent history of failure out-of-the-box, so if your present cylinder does NOT leak, its worth trying to resolve the sticking rather than replacing the whole cylinder & chancing more trouble.
quote:Originally posted by Rocky:
Do you have the original Autolite Spread Bore, or a later replacement?
