Webbers, from what I gather from previous postings from you. You have had continuous Clutch problems? am I correct?
1) Do you know how to
properly adjust your Clutch and especially the Linkage related to the Slave Cylinder?
2) Do you know how to
bleed the Air out of the Lines?
If you can
not answer yes to the two above questions you need to ask someone to do it for you who can do it the published (correct) way.
If you can answer yes to the two questions and have done the work/settings I would in your case start from an end and check everything associated with the Clutch operation. (don't yet pull your transaxle of the Engine to check Throw out Bearing and Pressure Plate)
Start from under the Dash and check if the Pedal linkage is lubricated and no obvious damage or excessive play etc. Then disassemble your Clutch Master Cylinder and check it. Disassemble your Clutch Slave Cylinder and check that one also. Check the Hydraulic Lines that there is free passage (in both directions). With the Slave Cylinder away also check that the Lever moves freely.
If everything is in good order then the trouble could be the Pressure Plate, The Pilot Bearing or the Throw out Bearing or any combination.
The Clutch system on the Pantera is very simple but MUST be operating exactly to specs or you can expect a lot of issues and damage your Clutch or ultimately your Transaxle.
This is just the steps I would follow if I should give you an advise. I bet there are other ways just wait and read more posts that will come from experts all around the world
