Ok, so I knew it was leaking...Thankfully it was ok for my hour or so drive home. Taking my kid for a ride the pedal went to the floor. Filling and bleeding got me home. It simply isn't holding pressure. No leaks in the boot.
So, I'm going to call and order a long-throw on Monday. Probably will order the fancy bracket as well. What else? My *red tube* is really hard, I was thinking of replaceing it. Doesn't someone have a ready to go braided line?
Also, is there anything special to replacing it? Looks like it bolts up easy enough, but I'm not sure how to adjust.
As usual, Thanks!!!
Its so hard to type this stuff. When I started out, the master was low. When it would no longer work, the master was empty. When I did a quickie bleed/fill to limp home, I was able to get pressure to drive, just still had air in the system, so it was dicey.
I do think the slave is leaking. The mechanic noticed it looked rough, said he could see signs of moisture, etc..
I know that you are correct that both should be replaced at this point.
