My clutch has been giving me trouble , so I checked my slave cylinder and have had it re built and it stays up a while, but after I drive it gets soft and looses it's tightness. We have bleed the line 3 or 4 times. Is there anything else i can do or does anyone know what the problem is. If if pump it up it will get tight for a while, while dring and then all of a sudden it goes to the floor. I have to pull over and pump it up. I see no leaks anywhere in front or back, but air may be getting in somewhere. I am about to loose my mind...... can anybondy help.
