I rebuilt my hydraulic clutch slave cylinder 29 years ago and now it has started to leak...again :-(
I just want to replace it with OEM or near OEM.
I am looking for a vendor/source (part #) and any recommendations (pre disassembly measurements, etc...) to make this as plug and play as possible.
Thanks,
Tom
Its on its way from Wilkinson and VERY reasonably priced (by my standard).
Originally posted by JAG13CAT:
I just recently replaced my clutch slave cylinder with one from Wilkinson (part # 05037A)and had no problem with the replacement. I originally was looking for a "long throw cylinder", but I understand it is no longer available. Most vendors offer the slave cylinder.
Tom, you may want to ask if it is a new one or a rebuild in a pretty Detomaso bag. I got one from that guy and a month later it was leaking, it was a crappy rebuild. He would not give me a refund. He replaced it but I did not use it. I got a new one from a different vendor. The second one he sent me was a rebuild also. I would hate for you to do the job twice like I did!
Confirmed new.
