joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
Looks to be a billet 11" (12kg listed) stock replacement flywheel, use your clutch of preference, except the Centerforce which demands using their flywheel as they use a different mounting hole pattern.
I just fitted the yella 9902L with exedy 6173D (for about 400hp) and Mcleod 16525 without any problems, but I haven't tried it on the road yet...... in 2 weeks I hope.
webbers1972 Pantera, Restored. How do I put pic on here?
1972 Pantera. I have to rev up my car to make it move. Made it into my garage. but, now when I put it in any gear, car wont move at all. Have clutch pressure, and can see the clutch move in and out. Is my Flywheel Glazed over?
I don't think your problem is the flyweel glazed, I'm thinking more of the setting.
Yella Terra 9902L + Exedy 6173D + McLeod 16525 (with all the shims) + Stock clutch master and slave cylinders works perfectly, smooth clutch pedal and no slipping.
