Evan,
If I'm not mistaken, the clock on the right is a real 1974 Pantera GTS clock and the one on the left is a generic Veglia Borletti clock. I see the style on the left being sold on eBay frequently and usually being described as an OEM Pantera GTS clock. You'll notice the real GTS clock has a bezel that matches the other Pantera gauges. I think the real OEM clocks are quite rare.
  • Generic_vs_OEM_GTS_Clock
My file photos conflict with what David related.
I vote for the clock on the left as being correct for Panteras. But the bezel style of the console gauges, as David pointed out, is a match for the clock on the right.
Used on the 150 USA GTS cars, and also on European models up into the early 1980s.
Larry - I thought I was wrong once but .... Big Grin
Mmmm the plot thickens. Any other votes????
Evan
Evan
My US GTS has the clock on the right in the post above with the even numerals. When I bought the car it was re-sprayed black, but very low mile and originally burgundy/black livery and had a completely stock interior. It came with literally every original part ever taken off the car, right down to the old v-belts. I'd say it's highly likely that the clock is OE for the car. I can send you VIN if you think it may matter in build sequence.
Best,
K
Evan
Best,
K
Good to hear because the clock in my car is missing and I have picked up an NOS clock like the one on the right.
My 74 is #7042
Evan,
You're lucky you found one because they are very hard to come by. Have you tested it to see if it works? I bought an NOS one years ago that was DOA. Both gauge shops I called said that was normal for NOS Veglia Borletti clocks made in the '60's or '70's because the lubrication dries-up. The good news is, they can clean and lubricate them to bring them back to life.
Originally posted by agustaboy:...I have picked up an NOS clock like the on on the right.
would that source have another?
No sorry just lucked out and asked one day on this forum. Some one answered and and now I have one. Thanks AZFAST1...
as for if it works... I've never had much luck in keeping clocks working in old muscle cars (not to mention battery drain in a car that sits 6 months out of the year) so I'll probably set the clock for 10:09 and leave it there.
