Our car has had a jazzy chrome thermostat housing fitted, looks like a 45 degree outlet - is this angle correct, or should it be 90 degree outlet? I've the original steel pipe off of this.
Also, what is the correct hose out of the water pump? It seems it needs to reduce from approx 45mm to 35mm - ours had this style fitted, needed cutting off to remove it sadly! (This is a Google image)
