I've installed a couple. People seem satisfied. Be careful to follow the directions EXACTLY. When they say to clean the bolts and threads, then use Lock-tite on the threads, they mean it! Many guys don't read well, and the bolts come loose with predictable results. The kit will adapt either stock rockers or roller rockers, and Ford SVO now also sells such a kit.
