This was todays project. I just threw this together. I have not proof read it but I will smooth it over a bit latter:
http://www.rc-tech.net/pantera1/decklatch/deck_latch.htm
Did you know some of the early push-button cars had a cable operated rear deck? Cable ran to a recessed Fiat-sourced release handle located in the driver's B pillar.
But the latch is not readily within reach from under the car, and with your cover, the guts aren't even open to a stretched-out hand.
Should a cable, or servo, go NFG you may have major issues.
Don't mean to rain on your parade. Your project would surely be on my list should some soccer mom ever crunch the back of 2511.
Just my 2¢
quote:Originally posted by r mccall:
Brilliantly executed! How do you plan to attach the cover? What did you make it from?
Ron
